Steps before rhodium plating 18kt white gold?
March 17, 2009
Hi,
The questions for which I don't have the answers are:
1. What are the processed that need to be taken before I can rhodium plate 18kt white gold?
2. How can I achieve them? (Tools required, and where can I source them from)
3. What are the ways in which I can check for them in case they were over looked?
4. And can the same steps be taken if I have to apply rhodium on yellow gold?
Thanks a lot for your help,
Student - Mumbai, Maharashtra, India
This is an article that explains the procedure you should use to get good results on your rhodium plating projects. www.ganoksin.com/borisat/nenam/ajm-rhodium-plating-technique.htm
Neil BellAlbuquerque, New Mexico
March 20, 2009
April 29, 2010
what THINGS I have to mix rhodium with ?
WHAT IS THE STEPS OF PLATING ?
WHAT IS THE TOOLS I HAVE TO USE ?
WHAT IS THE LIQUID THING ON PLATING?
- Damas, Syria
Hi, Omar. Neil has referred us to an on-line article with a good explanation of these things. Please try to cast your questions in terms of what the article says, rather than asking Neil to re-post. Thanks!
May 3, 2010
