Humidity endurance of type 2 class 2 coating
for type 2 class 2 sealed with nickel acetate, can it resist a 5% to 95% RH testing?
Angelo Atienza
engineer - Philippines
March 5, 2009
Hi, Angelo. Your question is a bit vague, but anodizing should re able to resist some number of cycles of a humidity test. Grades like 6061 will do better than the 2xxx grades though. Can you pose your question with more detail?
March 6, 2009
