  Thread 514/91
Need citric acid for cleaning steam sterilizer
I have a steam sterilizer and they said to clean with citric acid this on eBay or Amazon [affil links] . Where can I buy it? thank you
Andrea Saunders
housewife - England
March 4, 2009
publicly reply to Andrea Saunders
I am not sure what you are needing to clean up. If it is hard water deposits, dilute vinegar in bulk on eBay or Amazon [affil links] will work well (just be sure to fully wash with soapy water and rinse well to remove odor. Also, I think you could use lemon juice as a substitute for this application (the reconstituted kind in the bottle).
Hope this helps.
Gene Packman
March 10, 2009
publicly reply to Gene Packman
Try a soap making or wine making supplier, or local chemist. Hope it helps and good luck!
publicly reply to Goran Budija
March 11, 2009
Any shop selling 'home brew' supplies will stock citric acid .
Bur check out kettle descaling products. Many are based on citric acid and it should be listed in the small print on the label.
publicly reply to Geoff Smith
