How to avoid green corrosion of copper material after silver plating
I would like to ask about the issue refer to by my headline.. please give me further info on this.
Laily Roslan
silver plating of copper material - Malaysia
March 3, 2009
March 4, 2009
Hi, Laily. The silver plating is apparently not thick enough or is too porous.
Consider to use pre-silver plating.
Dominik Michalek
- Mexico City, Mexico
March 5, 2009
Second of two simultaneous responses -- March 5, 2009
Copper and silver migrate into each other with a vengeance at room temperature and with more vengeance with heat!
You must use a difusion barrier between the copper and the silver. Use nickel or palladium.
robert probert
probertbanner
March 6, 2009
ARE YOU DOING A NICKEL COATING BEFORE THE SILVER.?
2-3 MICRONS OF NICKEL PREVENT FROM COPPER DIFFUSION BETWEEN THE LAYERS
Ricardo Burstein
Bnei Berak, Israel
I THINK THICKNESS OF SILVER IS NOT PROPER.
PL. CHECK THE THICKNESS OF SILVER AND LET US KNOW IT.
REGARDS,
ajay raina
Ajay Raina
Ludhiana, Punjab, India
March 11, 2009
adv.:    Discover the choice made by manufacturers
nationwide for high quality jewelry plating & finishing
red sky plating banner
