Removing silver paint from Cast Iron Fireplace
We have a cast iron fireplace sitting in our shed that is covered in silver paint that we want off! We have plans to fit in our living room and have it as a working open fireplace, what is the easiest way to go about it? We are in the Bromley, Kent area.
Sarah Basten
hobbyist - UK
February 26, 2009
First of two simultaneous responses -- February 27, 2009
I think that most silver colored paint contains a good bit of aluminum. Try Easy Off oven cleaner this on eBay or Amazon [affil links] . The old one that has a high lye content to it. If that fails check with the paint store and see what they have for a stripper. All of these are nasty, so follow instructions to the letter.
If all else fails, build a really hot fire in it and see of you can burn it off.
Sand blast will remove the paint, but may remove too much iron with it.
How about a nice matte (flat) high temp black or gray paint over the silver. That is the cheapest and fastest way.
Try any solvent based paint stripper-it must work.Hope it helps and good luck!
Buy a can of Nitromors from a D-I-Y shop and follow the instructions.
geoff_crowley
Geoff Crowley
Crithwood Ltd.
Westfield, Scotland, UK
crithwood logo
March 3, 2009
Look up "powder coating" in your local "Yellow Pages". Phone two or three of them and ask the price to "shot blast" and "powder coat" using a polyester powder... a cast iron fireplace surround. They should be able to offer several colours and degrees of gloss that will meet your requirements.
Terry Hickling
Birmingham, United Kingdom
March 3, 2009
