Electroless Nickel is too smooth for my needs, I need a rougher finish
Manufacturing a locking system.
Currently we are using electroless nickel for our product and while the finish is excellent we find that it cannot grip good enough when we clamp it down to brass and copper fittings.
I think if we had a finish with a bit more texture a big part of our problem could be solved.
Any suggestions?
Many Thanks
Gary
Gary Moran
Manufacturer - Toronto, Ontario, Canada
February 26, 2009
You can ask your EN supplier to supply a matte chemistry. Also, consider some kind of roughening or texturing prior to plating your parts.
Guillermo Marrufo
Monterrey, NL, Mexico
February 28, 2009
You can do Glass bead blasting or whatever grits suits your need , and then ENP
Prashant Soman
Dist. Thane - India
March 22, 2009
