  Thread 513/91
REFINING USED GOLD PLATING SOLUTION?
February 24, 2009
Hi, I run a small Precious Metals Business.
I have about 300 liters of used gold plating solution that I think has gold still in it. What's the best way to refine it ? So far I have just been plating it out with my rectifier, using S.steel anode and cathode, then scraping off the gold and melting it in my furnace.. But I am looking for a better way to do it..
Thanks Wyatt
Wyatt Walker
gold supplier - Australia
publicly reply to Wyatt Walker
February 26, 2009
You might try plating out onto a mild steel cathode. Then, instead of scraping the gold off, you could briefly immerse it in a muriatic acid this on eBay or Amazon [affil links] bath. Then, the gold will just fall off and you can recover it from the bottom of the tank.
dave wichern
Dave Wichern
publicly reply to Dave Wichern
February 27, 2009
See my response to letter 51365
You will save yourself a lot of work and worry.
publicly reply to Geoff Smith
March 3, 2009
Thanks for the suggestions Dave and Geoff.
Geoff I am actually a refining company, and am doing the job for a customer. I have been doing it for years, but working with old plating solution is only a small part of my business. I was just looking for a easier way to do the job.
Thanks for the suggestion Dave, I am going to try using mild steel and then dipping them into muriatic acid. What strength muriatic should I use.
Thanks Wyatt
Wyatt Walker
March 6, 2009
When I did this type of Au recovery, I used 1:1 HCl/water. Still pretty "hot", but diluted so as not to be too fume-y.
The acid goes into pores in the loosely adherent gold deposit and dissolves a bit of iron beneath...and the gold falls off. They get consumed after a while, so don't use anything too fancy or hard to fabricate.
dave wichern
Dave Wichern
