Silver plating on female threads
I have a question regarding the silver plating done on some of the 316 female nut threads.. It is a standard that silver plating must be done on female threads used for critical applications and high temperatures. It is also known to aid in the prevention of galling. I would appreciate if anyone clarified as to how exactly Silver plating helps the above stated concerns, which are "high temperature application" and "galling prevention".
Thanks in advance
buyer - Bangalore, Karnataka, India
February 12, 2009
February 12, 2009
Hi, Karthik. I'm not familiar with silver being required for "high temperature", but I do know of it as an anti-galling agent. 316 stainless is a great material for fasteners, but 316 threaded onto 316 will definitely gall against each other -- this is sort of like a "cold welding" phenomena. Silver gives good lubricity and prevents the galling.
