Electroforming Bath operate at room temperature
February 6, 2009
My best regards to all plating colleagues. I am using wax as a mandrel material to produce different products from silver electroforming bath which work at room temperature and I am succeeding. Now I want to prepare a gold electroforming bath which will work at temperature less than melting point of wax mandrel, i.e.
50 °C . I woud like to be able to electroform to (800-1000)microns; bright finish is not necessary. Can any one help me ? What formulas, what the operating conditions pH value, and the type of anodes? No problem if the formulas is for application of alloy or pure gold plating.
Plating shop employee - Baghdad, Iraq
Temperature of the gold bath should not be a problem. Most pure, neutral ph gold plating solution temps are under 50C (122F). When you are plating 3.2 mil (800 microns) I would suggest a auto chem feeder to add so much gold per ampere hour. As far as formulas, it is best to go with a proprietary gold plating process. Because you have to buy the gold salts from a supplier, you may as well go with their bath. If it is a reputable supplier or distributor they can assist you with tech service. If you make the bath up on site, it will cost a lot less than buying a ready to use plating solution. As far as anodes I would use Platinum clad niobium mesh. Good Luck!
Mark BakerFellow Plater - Syracuse, NY, USA
February 10, 2009
As far as anodes are concerned, you should use gold. The most common electrolytes are cyanide based, but I would recommend you talk to your chemical supply house before you embark on making your own. Supply houses spend a lot of time and money developing new and better baths that will give you better performances. In the long run they are the best option. Some will even supply non-cyanide baths and this is a major advantage.
