Need brass tinted lacquer
I need a brass tinted lacquer (aerosol based) to spray on a silver metal substrate to emulate a brass finish. I believe that the product I am looking for may be called electrophoretic.
Barry McDaniel
hobbyist - Little Rock, Arkansas, USA
January 28, 2009
Hi, Barry. Electrophoretic lacquer is lacquer that is applied by e-coating (electropainting). This is an immersion process requiring factory equipment. What you are seeking is simply brass-tone aerosol lacquer. I am not sure of its availability, but try a major supplier like G.J. Nikolas [a finishing.com supporting advertiser]. Good luck.
January 29, 2009
nikolasbanner
"Clearcoats/Lacquers for Brass from G.J. Nikolas"
