Rubber to metal bonding with Viton B
I work in the custom rubber molding industry that manufactures seals for a variety of industries but mainly in the oilfield. I tend to have problems when trying to bond Viton B to a large metal surface by means of injection molding. I am using a chemlok recommended bonding agent for vitons but I am getting frustrated with the results. My surface prep consist of degrease, sand blast and then degrease on last time before applying the bonding agent to carburized steel.
Wayne Griffithjobshop employee - Houston, Texas
January 21, 2009
I would look at contamination in the blast step or the final degrease has oil in it. Yes even vapor degrease has some oil. A caustic tank frequently has a thin oil film. Manual degrease with acetone ⇦ this on eBay or Amazon [affil links] Warning! highly Flammable! or alcohol normally is not effective.
James Watts- Navarre, Florida
January 23, 2009
February 10, 2009
Wayne,
I am somewhat familiar with Chemlok adhesives - one of our sister plants makes it and we use many Chemloks in our own elastomer/metal bonding :)
Are you able to verify surface cleanliness prior to application? What is your application method and dry film thickness? Finally, which Chemlok system are you using?
Aerospace - Dayton, Ohio, USA
