NICKEL FREE ON JEWELRY
IN OUR SHOP WE HAVE BEEN TRYING TO GET Ni FREE JEWELRY
WE USE A LAYER OF 2.5 MICRONS OF Ag OVER A Cu LAYER (WE JUST SKIP THE Ni LAYER AND INCREASE THE Ag LAYER)
IS THERE ANOTHER WAY TO GET Ni FREE JEWELRY WITHOUT USING A Co , BRASS OR Pa LAYER ?, BECAUSE THOSE ARE SO EXPENSIVE
- PERU
Instead of silver you should use an alloy of Sn-Cu on top of the acidic copper. This alloy looks much like nickel and was designed especially for nickel-free jewelry.
Sara Michaeli
Tel-Aviv-Yafo, Israel
A white bronze consisting of copper:tin:zinc is a very good replacement as it also has leveling properties together with excellent corrosion resistance.
Karen Sant- United Kingdom
Q. I would like to know if nickel copper zinc alloy imitation jewelry silver plated and then electrophoretic coating would manage to cover the nickel and test nickel free if tested
Rick Wency- India
January 28, 2012
Hi, Rick.
I don't think that's quite the right question. At some point the lacquer and silver will become sufficiently porous that the wearer of the jewelry may acquire a lifetime of nickel allergy from it. The tests exists for the purpose of ensuring that people will not be exposed to nickel, so they will probably be revised as necessary to prevent this. Isn't there a nickel-free alloy you can use? Good luck.
January 30, 2012
