copper sulphate test over hard chrome plated surface
I am engineer in plating shop and we are processing hard chrome plating in an product. After plating we are doing buffing operation.
To confirm the chrome removal in the surface due to buffing, I have dipped the buffed samples in copper sulphate this on eBay or Amazon [affil links] solution.
Observations: I have noticed copper depositions in some of the buffed areas then and there.
Question: Will the copper deposit on fully chrome plated surface.
Can I conclude that there is presence of material removal
Arunachalam M
Plating shop employee - Coimbatore, Tamilnadu, India
January 20, 2009
Or you can conclude that you have an iron contamination in your buffing setup. Shape will give a bit of a clue.
