Removing latex paint from a wrought iron circular stairway
Goof Off (gallon)
I have a wrought iron stairway that comes from a loft to my living room in AZ. I would like to strip in place and then replace with a spray finish. The stripping seems to be my issue. I am not there all of the time so the odor is not the issue.
Bernice Franklin
home owner needing to remodel - Lebanon, OR, USA
January 16, 2009
January 18, 2009
Hi, Bernice. Starting with the mildest, Goof Off this on eBay or Amazon [affil links] can supposedly remove latex paint. Multistrip is, according to the manufacturer, an environmentally friendly way to remove paint. The most powerful but the nastiest is methylene chloride based Aircraft Stripper, but I would not use it inside.
The paint can also be removed by sand blasting, but I don't know how practical that would be in your circumstance. Good luck.
