Alkaline zinc-nickel plating
January 13, 2009
Tip:  Readers want to learn from Your Situation  🙂
(little can be learned from abstract questions, so many readers skip them)
For alkaline zinc-nickel plating, what is the result when the plate exposed to Aluminium Oxide (Blasting process)?
Izyan Khairunnisa Mohd Ruzlan
Research and development - Johor, Malaysia
January 14, 2009
Hi, Izyan. If you blast any plating or coating you will remove it. Please give us a hint where you are trying to go with your question; I am not understanding the situation you may have in mind. Thanks.
