Need the surface treatment on Inconel
I had the pressed part in 0.1 mm thickness Inconel (Cr20Ni80) as moving blades. The client requirement in Higher Heat resistant(700C) & not Shiny. Anybody can help me to propose the surface treatment on it. I try many method but the plating is failed with bad adhesion. Since, the material is too thin, not good to blasting.
Nick Poon
Manufacturer - HK
January 9, 2009
Are you sure your material is .1 mm thick? If it is, I don't see how anything can be done to it.
tony kenton
AF Kenton
January 16, 2009
