Plating peeling on phosphor bronze springs
I am applying nickel via rack plating in a watts nickel bath to phosphor bronze springs. When the part is bent the plating peels off. I'm guessing it's an activation problem. Does anyone know of a good activation procedure for phosphor bronze?
Billy MiddletonPlating shop owner - Augusta, GA, USA
January 7, 2009
Strike first in ACID copper sulphate ⇦ this on eBay or Amazon [affil links] plating solution, then nickel plate.
FIRST ACTIVATE WITH 5%FLUOBORIC ACID AND AFTER COPPER STRIKE PREFERABLE WITH CYANIDE COPPER BATH
Ricardo BursteinBnei Berak, Israel
January 13, 2009
