Hexavalent and trivalent salt spray hours?
Dear All
I need details of salt spray hours for both white & red corrosion as well as trivalent
& hexavalent passivation.
Does plating salt spray hours vary for trivalent & hexavalent with same coating thickness?
Can any one help me in this regard?
Others - Salem, Tamil nadu & India
December 10, 2008
I guess you might be interested in the following documents:
Replacement of Hexavalent Chrome Passivations on Galvanized Steel:
www.surtec.com/Publikationen/TagungsbandAESF.pdf
High Performance Alternative to Hexavalent Chromium Passivation of Plated Zinc and Zinc Alloys:
www.macdermid.com/industrial/pdf/SAEreport.PDF
Google is your friend :)
- Bielefeld, Germany
December 11, 2008
