Ni plating spot check?
Hello, is there anyone aware of a quick "spot check" for electroless Ni?
Florina VartolasMaterials Technical Specialist - Auburn Hills, MI, USA
December 1, 2008
A drop of concentrated nitric acid will attack EN and turn its surface black. Conventional electrolytic nickel will show attack but will not blacken. Remember that acids are hazardous and regulated. This test may be destructive to delicate parts or thin plating.
December 3, 2008
Test for what?
The spot check for nickel is nitric acid on a cleaned area. Turns green. Try it on a known sample to be sure of what you are looking for. This is a destructive test.
