Tell me about Aluminium Sputtering
I have queries on process method, atmosphere required for carrying out the Aluminium sputtering. Is Aluminium sputtering a patented technology? Would request experts to share your knowledge.
KASI SUBBIAH PERICHIYAPPAN
- Bangalore, Karnataka, India
November 28, 2008
Aluminum sputtering is not a patented process, and is fairly easy to do. Any magnetron can sputter aluminum at a very high rate.
jim treglio portrait
PVD Consultant & Wine Lover
San Diego, California
December 3, 2008
December 6, 2008
Well, in principle aluminum sputtering is easy. But sputtering rate is not really high at least as compared to copper or gold. So you need high power. Target cooling becomes an issue. Contaminant like oxygen, nitrogen etc may spoil the show. Arcing may become a serious problem.
Good luck if you're trying!
H.R. Prabhakara - Consultant
Bangalore Plasmatek - Bangalore Karnataka India
December 9, 2008
Thanks Mr.Jim and Mr. Prabhakara for sharing your expertise.
Going by reply from Mr. Prabhakara, I understand that vacuum would support Al sputtering process for optimum results.
May I request, If you could share some more informations on
1.Requirements for surface preparation prior to Al sputtering.
2.What would be the adherence level / implantation level of sputtering atoms at a painted surface.
3. Mr.Prabhakara, I'm not trying the process on my own,
Can you suggest me if there are any source available for this process in India.
Sputtering requires a good vacuum and a clean substrate surface. Sputtering onto a painted surface is not a good idea. Paint and vacuums do not get along well, and the sputtered aluminum is not likely to adhere to paint.
December 10, 2008
simultaneous replies December 16, 2008
for any nitride coatings with good adhesion one should have a a clean surface.
as I know the deposition rate for AL is high,so you should control the power according to your required thickness or deposition time.
the colour may look like milky white.
compared to sputtering PVD ARC is a controllable technique for Al deposition.
A.Murali Krishna
A.Murali Krishna
pvd process engineer
Pune, India
There are people with some experience in this field in Bangalore. You may get some information by searching the web.
December 16, 2008
