Avoiding corrosion from stainless cleat on aluminum "tinnie"
I WANT TO PUT A STAINLESS CLEAT ON THE FRONT OF MY TINNIE, BUT I AM BIT WORRIED ABOUT CORROSION BETWEEN THE CLEAT AND THE ALUMINIUM. IS THERE ANY PRODUCT I CAN USE TO PUT UNDERNEATH THE CLEAT OR ON THE BOLTS TO STOP CORROSION.
CHEERS
ADAM
FISHERMAN - QLD, AUSTRALIA
November 9, 2008
Hi, Adam. The best protection is no metallic path. If you are able to put plastic or gasket material in a way that keeps the bolts from metallic contact with the aluminum, that would be ideal. But this particular galvanic corrosion problem should not be a severe one anyway. Good luck.
November 14, 2008
