Abrasion resistance of type 3 vs type 2 anodizing
October 29, 2008
I received a question about the quantifiable increase in abrasion resistance between type 2 and type 3 anodize. We have never measured the abrasion resistance of type 2, so I don't have anything to which to compare our standard type 3 results.
Has anyone measured the abrasion resistance of a standard type 2 anodize, and if so, what removal rate (mg/ft2) did you obtain?
Supplier - Salt Lake City, UT
Some kind soul will probably have that information, but not many places do a wear resistance on type 2 as you know. The data that you will get will not be iron clad as there is a range of acid/temperature/voltage/amperage/time allowed for type 2 and for type 3 that will give a wide difference in the results.
James Watts- Navarre, Florida
October 31, 2008
