  Thread 501/57
Galvanized Wire Properties
September 29, 2008
my name is Christopher Ballance
I am an architect in Ireland. I am specifying soft annealed steel wire for contracts on suspended ceilings.
What I would like to know is, does it make any difference if the wire is electrogalvanized or hot dipped.
architect - Dublin, Ireland
publicly reply to Christopher Ballance
Galvanized is much thicker, so it has a much larger resistance to red rust corrosion. For indoor use, I would go with the cheaper one which will probably be the electroplated one. In the USA, the wire frequently has no coating other than mill scale.
publicly reply to James Watts
