Corrosion of Power Connector
September 26, 2008
We have a problem with corrosion of connectors in a unit we have produced, in this connector we have 4 pins (red:-48V, white and yellow: low Volt controllers; Blue: ground)
My question:
How come that red is always the first to corrode ?
Mads Frederiksen
Plating shop employee - Skive, Denmark
September 26, 2008
The red one is the anode (+) connection. In the presence of conductive moisture the anode will dissolve (corrode)
Keep the connections clean and dry.
don baudrand
Don Baudrand
(Don is co-author of "Plating on Plastics" [on Amazon or AbeBooks affil links]
           and "Plating ABS Plastics" [on Amazon or eBay or AbeBooks affil links])
