Left All-Clad Stainless Steel in Self-Cleaning Cycle in Oven
I left my All-clad Stainless steel frying pans in my oven during the self-cleaning cycle and now they have yellowed. Are these heat stains? Also, how can I get rid of the yellowing?
Patrick Barker- Cincinnati, Ohio, USA
September 21, 2008
September 21, 2009
Yes heat discoloration, you can remove with Brasso ⇦ this on eBay or Amazon [affil links] , or Wenol ⇦ this on eBay or Amazon [affil links] metal polish and a soft cloth (diaper material). DO NOT USE STEEL WOOL under any circumstances. If they are highly polished do not use any abrasive compound or abrasive pad. If they have a brushed finish, you can use a scotch-bright pad rubbing with the grain only.
Electropolishing will also remove the yellow and brighten the surface at the same time.
Cliff Kuschelectropolishing shop - North Vancouver, British Columbia, Canada
