Blisters on Zinc Plated Sheet Metal
Dear Sir,
We are in sheet metal parts, wherein zinc plating is carried out simultaneously,
in past 1 year we had a problem of BLISTERING, and this was stopped due to stabilization of processes, recently we have observed this problem back.
So, could you guide me to do root cause analysis on blister occurrence.
do share with me your experience for such kind of problems.
Kirtikumar Prabhu, Quality Assurance
- Goa, India
September 15, 2008
September 22, 2008
Hi, Kirtikumar. The single most common cause of blistering would be inadequate cleaning.
HI SIR,
As Ted Mooney said improper cleaning only leads to blistering problem. Improve your cleaning process and try.
GOOD LUCK
Shoban Kesarapu
Shoban Kesarapu
plating chemicals supplier - Secunderabad, A.P., India
September 29, 2008
