Nickel Plating an Aluminum/Copper Assembly
The local plating house says this isn't possible because of the acid baths to prepare the aluminum will attack the copper. I've seen assemblies that have been coated with what looks like a Sulfamate nickel coating so it must be possible. Any info would be appreciated.
Mel LimaProduct Designer - Seattle, Washington
September 17, 2008
September 22, 2008
Hi, Mel. The aluminum ought to be copper plated before assembly, but I would agree with you that it's probably not impossible (of course I haven't seen the parts).
