Remove Paint from Aluminum Window Frames
I need to remove old dark brown paint from aluminum window frames and I've tried the mineral spirits, scraping, sanding and the stuff is really stubborn ... any ideas?
Kevin Callanpainter - Gurnee, Illinois U.S.
September 18, 2008
Hi, Kevin. Aircraft Stripper should do it, but it's pretty noxious as it contains methylene chloride.
September 22, 2008
Well, I know I'm out of my league on this website -- I'm just an amateur trying to rescue my brown, anodized aluminum window frames from a really bad paint job by the super before I moved into my apartment. So, I'm just throwing myself at the mercy of you and your readers. I took your advice and bought the aircraft paint stripper, reading the back panel carefully.
Good activated carbon respirator
⇦ this on
Amazon [affil links]
mask: Check.
Chemical-resistant gloves: Check.
Common sense: Uh oh.
Is a plan to use this stuff inside an apartment -- as quickly as possible and then leaving for several hours -- reasonable, or laughable? And what do I even use to put the stuff on (I'm imagining dipping a brush into it and taking out a bare handle after it dissolves the bristles) once it's worked, what do I use to scrape the stuff off and then clean up the windows so they're safe to use again?
Please help -- the only alternative right now is the use of very ugly plaid curtains.
- New York, New York, USA
July 29, 2010
Hi Pamela. Safety and toxicity are relative, of course. Plan A would be to not need aircraft stripper, and Plan B would be to use it outdoors. But if you can get good flow-through ventilation with a fan and open windows, blowing the fumes away from you, and you only work for a few minutes at a time, it's called Plan C, not Pl...tonium. But remember goggles, too -- you don't want a drop in your eye.
The instructions on the can will tell you what kind of brush and how to scrape it. It's volatile (that's why you smell it), so I don't think there's anything to worry about regarding getting the traces off your window frames. Good luck.
July 24, 2012
