How to Do Electroless Tin Plating Over Electroless Nickel
I currently do electroless plating nickel on ceramic tubes. I want to electroless plate tin over the nickel. Can anyone tell me how to do this or where to find information.
Brett Michaudemployee - Portland, Oregon
September 19, 2008
Since the part is very hot coming out of the electroless nickel it may be partially passivating, so, lets go back thru a quick nickel chloride strike (Woods) and then the immersion tin.
Immersion tin as far as I know requires a copper substrate for the reaction to occur. Without copper, no replacement reaction occurs. Also, as opposed to electroless or autocatalytic deposition which continues to plate as long as there is a catalytic surface provided, tin only deposits as long as copper is exposed - once covered, reaction shuts down. Therefore, immersion tin is VERY THIN like 10 millionths of an inch.
Milt Stevenson, Jr.
Syracuse, New York
October 4, 2008
