Plating to Meet 1000 Hours of Salt Spray?
September 15, 2008
We supply automotive parts to some of the OEMs in Europe. Recently, we received an enquiry from one of our customers for new business. However, the part must meet 1000 hours of salt spray test.
Please suggest what kind of plating will meet this specification. The plating chemical should be free from all heavy metals.
Thanks and Regards,
Venkatesh
Automotive - Chennai, India, Tamilnadu, India
Are you currently supplying parts to customers that require parts be plated to 1000 hours of salt spray? Matt Heylockdelphi - Amherst, NY, U.S.A. September 19, 2008 September 19, 2008 Mr.Venkatesh, ![]() P. Gurumoorthi electroplating process chemicals - Chennai, Tamilnadu, India |
Dear Mr. Venkatesh,
Zinc-Nickel plating with minimum 10 micron thickness followed by trivalent passivation and top-coat will give you 1000 hours to red rust.
Alternatively you can try zinc-rich dip-spin coating which gives 1000 hours SST.
Both the above process will meet the ROHS requirement.
- Chennai, Tamil Nadu, India
September 22, 2008
HI SIR,
I think alkaline zinc-iron plating followed by trivalent black passivation and sealant will give you 1000 hrs SST. Try with that.
Shoban Kesarapu
plating chemicals supplier - Secunderabad, A.P., India
September 29, 2008
October 3, 2008
Dear Venkatesh,
Please tell what the colour of finish you need. There are zinc rich paints which give more than 1000 hours easily. That comes in grey and black colours.
plating process supplier - Bangalore, India
November 13, 2008
Dear Venkatesh,
Based on the part application we need to select the surface Treatment. we will do Zinc Alloy plating,Organic Coating(Ex-Geomet,Zintek) and Nylon Based powder Coating, or Paint in CED/Spray method we will do.
Is the thickness is low only possibility Plating with proper method, Thickness is not a problem we will go for Nylon Based powder coating. You will get all type's of Surface treatment supplier's In Chennai.
Is you are selecting the organic or powder coating. please do the Zinc plating with out passivation and then do the organic or paint coating
- Salem, Tamil Nadu, India
