How to get heavy gold plating (5 microns+)
Q.
**1) Could the expert kindly advise:**
a) When preparing a decorative gold plating solution with the following formula:
- HAuCl4
- CuSO4
- NTA
- K3C6H5O7
- KH2PO4
Should the pH be maintained at 3.5 or 3.8? (Note: The pH must not be higher than this range because if the pH exceeds 4.0, the gold plating solution using HAuCl4 as the gold salt --without free cyanide-- will precipitate and hydrolyze.)
**2) When preparing a *thick* gold plating solution with the formula:**
- HAuCl4: 3.75 g / 1 liter
- Citric acid: 30 g / 1 liter
- H2SO4 (10%): 20 ml / 1 liter
- Conductive salt NH4Cl: 5 g / 1 liter
- Brightener additive (Saccharin): 2 g / 1 liter
- Distilled water: Top up to make 1 liter
Does the preparation procedure for the thick gold plating solution differ from that of the decorative gold plating solution?
For example:
a) I plan to dissolve 1g of HAuCl4 in 200 ml of distilled water, then adjust the pH to around 2 or 1.5 (i.e., lower than 2) -- This is Solution 1.
b) Then, dissolve citric acid (C6H8O7) in 500 ml of distilled water -- This is Solution 2.
c) Next, gently pour Solution 1 (gold salt solution) into Solution 2 (citric acid solution) and mix well.
d) Then add H2SO4 and stir well to stabilize the thick gold plating solution.
e) Next, add the conductive salt NH4Cl.
f) Add the brightener additive Saccharin.
h) Finally, adjust the pH and top up with distilled water to make 1 liter. (Or top up with distilled water first, then adjust the optimal pH -- 4, 5, or 6 is acceptable.)
**Question:** Among the two pH adjustment methods above, which one is more appropriate?
**3) Could the expert please clarify:**
- For decorative gold plating, the pH is typically maintained between 3.5 and 3.8. (If pH exceeds 4.0, HAuCl4 in the solution will hydrolyze.)
- For *thick* gold plating (as per the above formula), the pH is allowed to be around 4.0, 5.0, or even 6.0.
**Question:** What is the main difference between these two plating processes and formulas (thick gold plating vs. decorative gold plating)? Thank you very much for your guidance.
**4) Could the expert kindly provide the full process parameters for thick gold plating using the above formula:**
- Ideal temperature for thick gold plating?
- Voltage?
- Amperage?
- Anode connection: Should the (+) anode be connected to stainless steel, titanium mesh, or 9999 pure gold? Which option is the most effective?
- Should the solution be stirred (magnetic stirring) or not?
And in the unfortunate case that the thick gold plating solution (prepared without free cyanide, as in the given formula) results in a dark or black finish rather than a bright gold appearance -- what is the likely cause?
How should the process or formulation be adjusted to achieve a bright, shiny, yellow-gold finish on the plated object?
Thank you expert
- Ho Chi Minh, Vietnam
April 21, 2025
A. Try old ferrocyanide based gold plating solution : 200 gms potassium ferrocyanide, 50 gms gold chloride,40 gms potassium carbonate,1 lit water.Stainless steel anode, dissolve ferrocyanide in boiling water, when dissolved add carbonate and as last add gold chloride, boil 30- 180 minutes, filter when cold and use.Hope it helps and good luck!
April 25, 2025
Q. Hello Sir,
I have been told that with flash gold plating solution there is a way to get 30-50 microns of gold onto jewelry. A person told me he have looked in a 'history of plating' book, he found that if you put about 5 times the normal amount of gold into your bath, lower the voltage and increase plating time, you can plate that thickness in an hour or so and have it come out bright. This will give a very thick and durable coating of gold. Is it possible or not -- please advise me?
I want to plate 30 to 50 microns of gold on a watch. Note:I'm not talking about 30 to 50 microinches.
Dipen Pattni
jeweler/goldsmith - Dar-Es-Salaam, Tanzania
A. Hello, Mr. Pattni. The word "flash" usually means very thin.
30-50 microns is very very thick; I don't think even the famous century-old pocket watches had more than 20 microns. Today's super-premium watches reportedly have about 7 microns. ![]() Ted Mooney, P.E. Striving to live Aloha finishing.com - Pine Beach, New Jersey A. I have seen gold plated over 1/2 inch thick but we sure did not call it "flash". The term flash is not used in the USA for heavy deposits - flash usually means about 0.000 010 inches thick or 1/4 micron. ![]() Robert H Probert Robert H Probert Technical Services ![]() Garner, North Carolina ![]() |
Q. Dear Ted,
I don't know the type of bath, but I'm buying solution from my supplier and I'm adding 68% GPC in the instagold flash bath 2 grams per gallon.
My supplier is telling me you can plate but you have to add brightener and 1 oz of GPC per gallon and you will need lot of agitation then I can plate very thick.
I want to plate 50 micron on watch, base metal is brass and SS. Please advise me is it possible or not, or I need different type of bath?
Dipen Pattni
by Reid & Goldie
-- hard to find & expensive; if you see a copy cheap, act fast!
AbeBooks
A. I'm not a hands-on gold plater, Dipen -- just a guy who reads and listens and watches. 'GPC' (gold potassium cyanide) means it a cyanide bath, which is usually not considered the best basis for a high-speed gold plating bath, but I think your supplier is advising you correctly and that you can plate a heavy thickness by increasing the gold concentration, using agitation, and employing a proper brightener.
Q. Dear Ted :)
I know you read and listen and watch. I'm sure that my bath is not a cyanide strike bath. Anyway I'll spend 1 oz of GPC and brightener to let see what happens ;(
My supplier is Gold Touch [a finishing.com supporting advertiser] they have advised me a lot but they have never done heavy thicknesses like I want. So I thought let me post the question on finishing.com, masters like Mr.Ted or others can help me. My english is not good, please try to understand.
Dipen Pattni
sometimes on
AbeBooks or Amazon
A. It's not clear to me if you are running alkaline cyanide gold or acid gold cyanide. What is the pH?
According to Al Weisberg's great article in the Metal Finishing Guidebook, you should have 4-8 g/L of gold for heavy deposits. This is much much higher than you previously had. He notes the use of either cobalt or nickel for alloying, agitation required, a current density of 10-20 A/ft2, and temperatures between 80 and 100 °F.
Q. Dear Mr. Ted,
Solution powder itself does not contain the cyanide, type of bath is acid gold bath that is both electrolytic and immersion, pH is 4.4 to 4.8.
Dipen Pattni
A. Hi. I'd bet that powder is GPC, potassium gold cyanide. If so, this bath is usually called an acid gold cyanide bath.
Q. I don't seem to be able to get a straight answer from my supplier. I'm currently using a cyanide based gold plating solution. This is one of the common solutions used in the Jewellery business. I'm gold plating base metal rings and I cannot get a thick coat of gold deposit on the items. The directions for the plating bath are the following:
Heat at 130-140 °F and plate with 5-6 Volts for about 15-30 seconds, using a Stainless Steel anode.
By doing that I only get a flash and sometimes when I lightly buff the piece with a cloth the plating goes away. I tried to lower the voltage to 2.5-3 Voltage and increase the plating time to about 1.5-2 minutes. The same happens. And when I plate for about 5 minutes the plating becomes too dull and dark.
Another company sells a K24 gold plating solution that according to what they say it will plate 2 microns in 2 minutes. And if I need to pate thicker just leave it longer and then wipe the piece to remove the dull finish. I don't know if I can trust this.
Any ideas? I need to have a bright thick gold plating that will last for years. A plating I can engrave on.
Thank you in advance for your time.
Jewellery and watch case plater and refinisher - Montreal, Quebec, Canada
September 12, 2008
A. The company that told you they have a gold bath that will plate 2 microns (over 80 microinches) in 2 minutes was in error, unless the gold concentration of the bath is way up there, and who can afford that nowadays. Secondly, the bath you are using now is made for what you say, "a flash coating". The bath could also be low in gold. The deposit should not just rub off, even at 5-7 microinches thickness. Why do you want to plate 2 microns of gold on jewelry? If you want a thicker deposit you will have to increase the gold concentration and other constituents in the bath. You could plate 25 microinches max if you want a quality product. You will have to sell the rings for a lot more though because you are putting on almost 5X the amount of gold than the average jewelry plater. Good Luck!
Mark Bakerprocess engineer - Malone, New York
Readers who are interested in the formulation of baths, and the operational considerations, for very heavy gold plating may also be interested in these related threads:
• Topic #348/21 "Gold flash vs. plate"
• Topic #30/00 "Problems in Gold plating"
