How to remove metallic impurities in cadmium bath
Hello sir,
I was facing a problem with my cadmium bath which contains cadmium, sodium cyanide and caustic soda ⇦liquid caustic soda in bulk on Amazon [affil link] .The problem was white patches in low current density areas then I consulted my chemical supplier they says that the bath is contaminated by impurities and suggested dummying the bath. I want to know any other process to remove impurities other than dummying.
Ranga Reddy
plating shop - Kushaiguda, India
September 12, 2008
November 7, 2009
Hi, Ranga. "Too many cooks spoil the broth".
If you are going to use a proprietary plating chemistry supplier, there is a lot to be said for following their instructions about how to fix the problems with the baths, rather than half-following them and half doing contrariwise :-)
But if you would like to better understand the troubleshooting of plating baths, and the treatments to address difficulties, the Canning Handbook is a wonderful resource. Good luck!
