How to select DM Water Plant
September 7, 2008
Dear Sir,
I want to know what are all the parameter to be consider to go for DM water Plant.
Example - TDS value,PH value,contamination,flow required and hardness in our raw water.
like above parameters we need to understand other parameters also.
Automobile industry - Chennai, India
Typically, you decide on the quality of water that is needed for your intended purposes and then find the most economical method of getting those parameters. You may have more than one DM system as some might only require removal of calcium while possibly there could be a use for 2 Meg Ohm water. The cost per gal of each is massively different.
So, what do you need? Only you can determine that.
