Stripping nickel from brass
Hi, I try to strip nickel from brass but I am unsuccessful when I used chemicals (which I don't know the formula - bought from a company )working electroless.
I am studying for the chemicals that is used with electrolytic , so can you advice me which chemicals can I use when it is electrolytic?
Lütfiye Can
- Istanbul TURKEY
September 5, 2008
First of two simultaneous responses -- September 12, 2008
Dear Mr. Can,
If you need to strip nickel from brass, then I recommend to use Golpanol MBS (sodium nitrobenzene sulfonate) from BASF company.
As far as I remember it right now you need 100 g of Golpanol MBS and 180 g of concentrated sulfuric acid for 1 litre of ready-for-use stripping solution.
Temperature: about 60-65°C
1. Soak until all the nickel has been dissolved and a black film will cover the stripped parts.
2. Water rinse thoroughly.
3. Soak the parts in a 3-5 % sodium cyanide solution in room temperature until the black film has been removed.
4. Water rinse and dry up.
5. Slightly re-polish.
But you can also ask BASF for help, they offer standard formulations.
Hope that helps!
Martin Michel
- Bielefeld, NRW, Germany
Second of two simultaneous responses -- September 14, 2008
Hi, I would recommend Ni-plex .
Bot sure of the make up but I'm sure you will find it on this site.
hope this helps
Jay Smith
- Essex, UK
Thanks for the help, folks. To the extent practical, let's keep the discussion non-proprietary. I'm sure that you can appreciate that the site's supporting advertisers might be reluctant to fund a forum where we spend their money posting recommendations to use their competitors' products :-)
September 14, 2008
Hi, Martin I tried your recommend but it took 1.5 hour so again can I ask that is the solution can be used electrically?
Lütfiye Can
ADA - Turkey
September 16, 2008
