Electric Polishing of Brass
I have brass handles on all the doors of my home, after ten years the outside handles have weathered. I would like to know if there is an electric brass polisher and if so the brand as it will be a big job to polish them all.
Deborah Gallen
Housewife - Australia
July 29, 2008
July 31, 2008
Hi, Deborah. Maybe I'm misunderstanding you, but as far as I know there is no machine for consumers specially designed for polishing brass. I think you are looking for a buffing machine of some type, and for one-time use this may be a buffing wheel for a bench grinder, an angle grinder this on eBay or Amazon [affil links] with a buffing wheel, a buffing wheel for an electric drill, or even a Dremel this on eBay or Amazon [affil links] . You would try some polishing compound that has a bit of cutting action. Mothers Mag & Aluminum Polish this on eBay or Amazon [affil links] has worked well for my family. But before deciding that power buffing is required, you might try just brass polish. There are dozens of brands, but Revere Copper Cleaner this on eBay [affil links] is one that seems to have enough acid in it to work quite quickly for me.
