We burned cadmium parts by accidentally plating at 2-3 times normal amperage
July 24, 2008
What happens if during cadmium plating process to a steel part HT
200 to 300 KSI, the amperage utilized is excessively high (2 or 3 times above necessary or more) for the area and thickness required? It's possible to burn the part and the metal became brittle? Thanks a lot.
Sincerely
Jorge
aviation tech - Miami, Florida, USA
July , 2008
Unfortunately, I think the parts probably must be scrapped. Jorge. When you plate at a higher current density than the solution allows, what that really means is all those extra electrons at the cathode cannot reduce cadmium ions to cadmium metal because there is insufficient cadmium within the boundary layer. Yet the current is flowing, and the explanation is hydrogen ions are being pulled out of the water and converted to atomic hydrogen (hydrogen gas). Operating a plating process at 2 to 3X the recommended amperage produces a huge amount of atomic hydrogen to cause hydrogen embrittlement.
