Zinc white trivalent
what is the difference between zinc white & zinc white triavalent.
Nagalingam Mahalingam
Customer - Chenaai, Tamilnadu, India
July 22, 2008
Hi, Nagalingham. "Trivalent" means the conversion coating after the zinc plating is trivalent chromium rather than hexavalent, which is necessary for RoHS compliance.
But this terminology is loose and imprecise, so one cannot put a sharp point on it. In fact, this terminology is even sloppier than usual because the word 'white' is used as a substitute for 'clear'. It only makes a poor description even worse :-)
July 22, 2008
