A housekeeper's blunder leaves every silver piece looking like aluminum
Q. Dear sirs;
Recently my housekeeper cleaned ALL my silver; flatware and candleholders with an abrasive pad and cleaner. All the silver is scrathed making it have the appearance of aluminum. How can I restore this myself? I am willing to invest in any contraption that will bring the items back to their original beauty. I can't, at this time, consider having it professionally done because there is so much to restore. Please advise me of my options.
Thank You,
Michael Stout
Patron of fine silver - Brewster,New York, U.S.A.
July 13, 2008
Precipitated Chalk /
Calcium Carbonate
A. Try precipitated chalk/water mixture(thick).After that polish with special silver polishing cloth.Hope it helps and good luck!
simultaneous replies July 17, 2008
Most shops specialized in silverware have polishing compounds (Simichrome this on eBay or Amazon [affil links] brandname comes to mind).
G. Marrufo-Mexico
Guillermo Marrufo
- Monterrey, Mexico
Michael
If you can locate some, a paste of Colgate Tooth Powder works well at fine polishing. May be too fine, depending on the abrasive originally used.
Willie Alexander
- Colorado Springs CO
July 17, 2008
Polish lightly with 2F pumice this on eBay or Amazon [affil links] and then switch to 4F fine pumice this on eBay or Amazon [affil links] in a wet paste. Lots of work.
If it's sterling, then you can restore it with buffing pads mounted in a hand drill and white compound, both available at Sears.
If plated, there may not be enough silver left to allow restoration. It would have to be replated, which costs about as much as new.
