Electroforming isn't sticking to steel surface
Dear Sir,
I am a beginner in electroforming process. I tried using electroforming using Nickel+Cobalt to try to restore worn part in mould. However the "electroformed" portion is observed to have low adhesion with the steel surface.
Would appreciate any advice / suggestions on how to improve the bonding / adhesion of the electroforming metal with the steel surface.
Best Regards,
Tjang Wie Koan
Wie Koan Tjang
Surface Plating - Indonesia
July 6, 2008
Hi, Tjang. 90 percent probability that the steel simply isn't clean enough and active enough. After whatever you are presently doing, scrub the area with powdered pumice this on eBay or Amazon [affil links] and a tampico brush. Rinse it well. Sponge it with clean muriatic acid. Rinse it. Plate it. Neutralize with sodium bicarbonate and tell us how it went. Good luck.
July 9, 2008
