Plating steel with aluminium
Some of my students have used a battery acid ⇦ this on eBay or Amazon [affil links] bath for anodizing aluminium. For unknown reason, some of them used aluminium at the negative pole, and steel at the positive pole. It seems to be possible to coat steel with aluminium this way. Can anybody help me determine, if this is the case, and if it is, what is the reason?
Mikael Højbjergphysics teacher - Aalestrup, Denmark
July 5, 2008
July 8, 2008
Hi, Mikael. No, it is not possible to plate aluminum this way. Water will hydrolize to hydrogen and oxygen long before any aluminum can be reduced. Aluminum can only be plated out of molten salts or non aqueous solvents.
