What material for rustproof 3" dia. disc to cover old key hole?
July 2, 2008
3" diam. disc needed to cover old key hole in a gate ON the Atlantic Ocean coast.
What material should I use so that it won't rust?
thanks.
Sylvia Jacobs
condo manager - Miami Beach, Florida
July 6, 2008
Hi, Sylvia. Type 316 stainless steel would be ideal. But what is the gate made of? Whu not make it of that?
Sylvia,
I would suggest stainless steel as being the simplist and probably the easiest to locate. Have you considered using plastic i.e. PVC
Gene Packman
July 5, 2008
Ideally, you say I can use 316 stainless steel. Here is a picture of what I speak...the knob on this gate is aluminum.
49206
what are my chances of using the disc of aluminum.......
where would I find a 3" disc in 316 stainless steel? I intend to have the letter G engraved on it. (I need two discs.) thanks so much for working with me on this....
Sylvia Jacobs
July 10, 2008
