Stainless compatibility with trivalent CCC on aluminum casting
Q. I'm experiencing what I think is galvanic corrosion of a stainless part used in an assembly with a trivalent CCC aluminum die cast part while salt fog testing. Is it truly galvanic corrosion? If so, what is the mechanism?
Matt Byrne
engineer - Cleveland, Ohio
July 1, 2008
A. Hi, Matt. I would doubt it since stainless is far more noble than aluminum.
July 1, 2008
thumbs up signThanks Ted. I am also going to investigate the possibility of crevis type pitting corrosion. The stainless part is press fit into the aluminum part with very tight tolerances.
Matt Byrne [returning]
- Cleveland, Ohio
July 3, 2008
