Thread 491/24
Substitute for cyanide in cleaning solution
June 24, 2008
we need to remove the oxide layer formed on the copper surface by the high temperatures . Now we use a solution of acetic acid
⇦ this on
Amazon [affil links] and boric acid, but this solution doesn't remove all impurities.
Before this solution we worked with a solution of Cyanide with better results, in addition this solution removes small residues of vitreous enamel. When the plant was transferred it was necessary to change this process.
Do you know other solution with similar properties of the cyanide?
customer - Matamoros, Tamaulipas, Mexico
publicly reply to Oswaldo Montes
Hi, Oswalso. Nitric acid is certainly not a direct substitute for cyanide, but it is used for removing scale from copper; I doubt that it will remove vitreous enamel.
June , 2008
publicly reply to Ted Mooney
