What is the Process of Plating Platinum and Titanium Dioxide to Stainless Steel SUS 304/316L
I have already checked out the basics Electroplating -- How It Works
I need to get some SS tubes coated with Platinum and some with Titanium Dioxide, How do I do that?
I will need these in an experiment involving production of Hydrogen by Electrolysis / Sun light etc. And I am stuck in the middle of a country were they do not understand what I am talking about. (Read Norwegian in Thailand!)
I know I am talking about some of the toughest materials but ... You never know. Maybe someone have a wonder cure for me!
Bjornar Vaageng
Wanabe inventor - Roi-Et, Thailand
June 13, 2008
Why tubes?
Platnitized titanium anodes used in metal recovery from waste solutions are normally en expanded titanium. There are a few companies that also make a multiple oxide coating on titanium (I will guess that it is some kind of thermal spray process) and then the really good ones are plated with iridium)
Some anodes are plated with platinum and some are "clad". I have no idea which is better.
Now to get water to electrolyze, it has to be very conductive, so what are you going to use? Salt will have chlorine come off with the oxygen and that might not be good.
Until you get your system perfected, I would buy commercial anodes or have your anodes commercially plated. Platinum costs too much to set up a line for a few parts and there is a steep learning curve for high quality parts.
