Sheet metal surface variation measurement info requested
I am trying to measure sheet metal surface defects. Traditionally we use visual inspection to do this. However, visual inspection does not pass a gage R&R (repeatability & reproducibility) test. It is the industry standard for automakers.
However, I need to find a better way to quantify (preferably with variable not attribute data) defects in body panels. I would welcome any thoughts that anyone would have at this point. THERE ARE NO BAD SUGGESTIONS. Please share your expertise. Thank you, Greg
Gregory L. SabinFord Motor Company - Dearborn, Michigan, USA
Greg,
What does Ford do with products that do not pass inspection, for production cars/trucks?
Chris Vesely- Lincoln, Nebraska
