Gold plating adhesion
Any past articles regarding adhesion of gold plating on crs steel. only requirement from customer is no under coatings (nickel strike etc..)can be used. thanks rv
Paul Bernardyplating shop - Denver, Colorado, USA
June 3, 2008
June 5, 2008
Hi, Paul. Yes, use the search term 'gold strike' and you will find at least some general discussion about acid gold striking.
