Avoiding hydrogen embrittlement by non-aqueous plating
June 3, 2008
Dear Sir,
I am a student of Physics and came across Hydrogen Embrittlement,
I know that one of the factors involved is water based plating solutions and electrolysis taking place. Free H is being formed on the Cathode and becoming trapped under the Zn.
Question in point, Would the development of a non water-based plating solution help reduce the H Embrittlement problem?
Student - Rockford, Illinois, USA
June , 2008
Hi, Brad, I think it would. Some plating has been done from molten salts and a lit search in that area might produce some results. Good luck.
I know that in the mid 1970's Dr. Abner Brenner was spending his "retirement" working on non aqueous plating processes. I do not know if anything was ever published about his work.
Gene Packmanprocess supplier - Great Neck, New York
June 9, 2008
What is wrong with mechanical plating? It has zero embrittlement.
James Watts- Navarre, Florida
June 10, 2008
There is currently increasing interest in the use of "ionic liquids" for electroplating. These are usually organic liquid mixtures that are capable of carrying an electric current. The technology has been successfully used to electrodeposit aluminium and other "non-plateable" metals. Their benefits are that they do not suffer from hydrogen evolution, so this reaction is eliminated from any electrochemical process, thereby allowing new metals to be electrodeposited. Since there is no hydrogen discharge, there is no risk of hydrogen embrittlement. Furthermore, these systems can be recyclable, but they are not always as cheap as conventional aqueous systems. Ionic liquids also have an electrochemical series, that is dependent on the ionic liquid being considered and is totally different to the conventional aqueous electrochemical series.
High strength steel parts subject to marine environments such as naval aircraft landing gear are normally cad plated and baked then painted at the manufacturing facility. When the craft is on duty the paint and plating may get damaged exposing the substrate. The brush plating industry partly owes its growth to the success to formulate no-bake cadmium plating solutions used for in-situ repairs of this kind. The damaged parts can now be re-plated and painted without post-bake, sometimes still attached to the plane which can be put back to service immediately.
June 16, 2008
