Low temp. black oxide line setup
Need to know what are the hurdles for setting up low temperature black oxide (100 gln.) line in Ontario Canada.
Harch Bedi
metal polishing services - Toronto, Ontario, Canada
May 11, 2008
Hi, Harch. Our FAQ on Black Oxide and Cold Blackening will give you a quick intro. These coating processes are proprietary, so I 'd suggest you contact a vendor like our supporting advertiser EPI / Electrochemical Products Inc. [a finishing.com supporting advertiser] or Heatbath for advise regarding the requirements. Good luck.
May 12, 2008
birchwoodYouTubeBlackOxide
