Grit blasting SA 2.5
I HAVE AN INQUIRY FOR GRIT BLASTING SA 2.5 WHAT IS THE TECHNIQUE AND MATERIALS USED FOR SUCH METHOD? AND THANKS FOR ANY SUGGESTION.
BASHAR THABIT
CONTRACTING COMPANY ENGINEERING DEPARTMENT - BAGHDAD, RESAFA
May 6, 2008
May 9, 2008
You need a mid-size compressor (90-100 PSI, 10-60 HP depending on area to be blasted), suitable hoses, pressurized reservoir with opening to load blasting media and discharge pipe outlet, angular (fractured) steel shot, nozzle 3/8"-1/2" of inside diameter (ceramic or tungsten carbide preferred but hardened steel also possible), operator (either in cabinet with gloves or covered with rubber or rawhide apron this on eBay or Amazon [affil links] and rubber gloves this on eBay or Amazon [affil links] and suitable face shield this on eBay or Amazon [affil links] ). Look for shot blasting equipment in your preferred search engine for pictures of system.
Guillermo Marrufo
Monterrey, NL, Mexico
