Jeweler's rhodium plating starts coming out black?
Can someone please, enlighten me.....I am using a 100 ml pyrex to rhodium plate about 12 pieces mens ring, which was finally polish with red jeweler's rouge this on eBay or Amazon [affil links] , heating the solution for about 3 mins in an electric stove and using a 3 volt DC rectifier with platinum plate connected to the positive terminal I started to plate the rings, I finish the 7th ring when I notice that the 8th ring and so on the 10th were black in color? can we recover back or clean dirty rhodium sulphate? please help...Ernny
Ernesto Belangoy
goldsmith - Cavite, Philippines
May 5, 2008
May 5, 2008
Hi, Erny. Do you have any way to check the rhodium concentration? I hate to state the obvious, but if you plated 7 rings from the solution and now you can plate no more, is it possible you used up the available rhodium?
